rickywray2
Apr 19, 2020Aspirant
ReadyNAS VPN Disconnected
Hi, ReadyNAS 204 that has worked fine for years with my old laptop. Got a new MBP and installed the ReadyCloud client app v1.7 and signed in using my ReadyCloud user/pass. All fine. Finds the NAS, b...
JohnCM_S
Apr 25, 2020NETGEAR Employee Retired
Hi rickywray2,
Welcome to the Community!
May I know the version of the macOS?
Have you also tried un-installing then re-installing the app?
Also, if you have any security software on the computer, can you try disabling that, then check if you will still get the same issue?
rickywray2
Apr 30, 2020Aspirant
Thanks. Catalina 10.15.4. Yes reinstalled once. no difference. Yes I have SEP (Symantec Endpoint Protection) enabled, however this was true fot the last MBP I had that worked fine. It is locked by my company and I cannot turn it off.
Any other ideas?
Regards
Richard
