McBeta
Mar 30, 2013Aspirant
ReadyNAS X6 is now called what?
I have a ReadyNAS X6, and I'm wondering what new part number it was given. It's a Sparc-based system: (formerly ReadyNAS 600) Model: ReadyNAS X6 Serial: 000da2006254 Firmware: RAIDiator 4.1.10 ...
mdgm-ntgr
Mar 30, 2013NETGEAR Employee Retired
NetGear no longer maintains a compatibility list for the old Infrant models.
Take a look at disks on the list for the NV+ (v1). That is another Sparc NAS and disks that work with that will probably work fine with the X6. Yes 2TB disks are the maximum supported.
It's recommended to use a minimum of 256MB RAM with RAIDiator 4.x. You may wish to consider replacing the RAM (even though that is not supported).
