McBeta
Mar 30, 2013Aspirant
ReadyNAS X6 is now called what?
I have a ReadyNAS X6, and I'm wondering what new part number it was given. It's a Sparc-based system: (formerly ReadyNAS 600) Model: ReadyNAS X6 Serial: 000da2006254 Firmware: RAIDiator 4.1.10 ...
McBeta
Mar 31, 2013Aspirant
Thanks. Sure seems a bit cheaper now! I'll check the rev level on the board, although I think it must be A. Likely I'll get the same 512M DDR PC2100 that was quoted in the post that you found & referenced.
Pat
Pat
