McBeta
Mar 30, 2013Aspirant
ReadyNAS X6 is now called what?
I have a ReadyNAS X6, and I'm wondering what new part number it was given. It's a Sparc-based system: (formerly ReadyNAS 600) Model: ReadyNAS X6 Serial: 000da2006254 Firmware: RAIDiator 4.1.10 ...
jodr
Apr 04, 2013Aspirant
Thanks for your answer, chirpa!
- So that should mean that I can install current 2TB-drives that are sata-III onto this sata-I interface?
- RAM: 128MB still enough or need I double it to 256MB?
- Installation procedure is plug and play? Retire the old disks, insert the new ones, wait until the disks are configured and formatted, reinstall Raidiator?
Best regards,
Johan.
Best regards,
Johan.
