McBeta
Mar 30, 2013Aspirant
ReadyNAS X6 is now called what?
I have a ReadyNAS X6, and I'm wondering what new part number it was given. It's a Sparc-based system: (formerly ReadyNAS 600) Model: ReadyNAS X6 Serial: 000da2006254 Firmware: RAIDiator 4.1.10 ...
Apr 04, 2013Guru - Experienced User
SATA is not an issue, all SATA drives will run on a SATA-1 interface. SATA is backwards compatible.
You will want to do a factory default (rebuilding the NAS from backups) to go with 2 TB drives. You need 4K alignment to get good performance, and that requires a factory default done on 4.1.7 or later.
