McBeta
Mar 30, 2013Aspirant
ReadyNAS X6 is now called what?
I have a ReadyNAS X6, and I'm wondering what new part number it was given. It's a Sparc-based system: (formerly ReadyNAS 600) Model: ReadyNAS X6 Serial: 000da2006254 Firmware: RAIDiator 4.1.10 ...
chirpa
Apr 04, 2013Luminary
As Stephen said, I would start fresh, not X-RAID expansion, if possible.
If you can find an old 256MB DDR1 stick around, give it a try, will help some. In the later firmwares, more daemons are running on the system, using more resources, so more RAM the better.
