McBeta
Mar 30, 2013Aspirant
ReadyNAS X6 is now called what?
I have a ReadyNAS X6, and I'm wondering what new part number it was given. It's a Sparc-based system: (formerly ReadyNAS 600) Model: ReadyNAS X6 Serial: 000da2006254 Firmware: RAIDiator 4.1.10 ...
jodr
Apr 05, 2013Aspirant
OK, Chirpa, thanks for the memory advisory. As for the X-raid expansion, I was not even aware of this possibility. However, taking your advice, I'll start all over. This is a procedure I found somewhere:
1.Backup all data
2.Verify backup is good
3.Upgrade to latest RAIDiator for your NAS if you haven’t already. You can check the latest version of RAIDiator under System > Update > Remote in Frontview. If a newer version than what you’re running is offered, update. Be sure to reboot the NAS when prompted to complete the update.
4.Optional – If you don’t want to reconfigure the NAS manually and would rather restore the NAS configuration after the factory reset, do a System > Config Backup (keep the zip file that is downloaded as this is what you will need to restore later).
5.Power down the NAS, remove old disks (label order) you no longer wish to use in the NAS, if any.
6.Put the new disks in the NAS and do a factory default using the ReadyNAS boot menu
7.Optional – if you don’t want to reconfigure the NAS manually, restore the Config Backup.
8.Restore data from backup
Is this still correct?
Johan.
1.Backup all data
Johan.
