McBeta
Mar 30, 2013Aspirant
ReadyNAS X6 is now called what?
I have a ReadyNAS X6, and I'm wondering what new part number it was given. It's a Sparc-based system: (formerly ReadyNAS 600) Model: ReadyNAS X6 Serial: 000da2006254 Firmware: RAIDiator 4.1.10 ...
Apr 05, 2013Guru - Experienced User
There is one missing step. You need to reinstall any add-ons before you execute step 7. If you don't do that, you end up with the system thinking that add-ons are installed when they are not. If that happens, frontview won't let you install over them, and it won't let you remove them either.
