McBeta
Mar 30, 2013Aspirant
ReadyNAS X6 is now called what?
I have a ReadyNAS X6, and I'm wondering what new part number it was given. It's a Sparc-based system: (formerly ReadyNAS 600) Model: ReadyNAS X6 Serial: 000da2006254 Firmware: RAIDiator 4.1.10 ...
jodr
May 08, 2013Aspirant
Hi, Marto, thanks for your reaction!
Meanwhile I had opened a support ticket and was advised to do an OS Reinstall (holding the reset switch, power on, wait 5 seconds). Have done this yesterday evening and this worked well. It took some time (half an hour), but now V4.1.10 is installed and is working well. FYI, my box is a ReadyNAS 600. So now I'm set for the next step and will look to replace the current disks (300 GB) with 4 disks of 2TB to upgrade capacity of the box.
Best regards,
Johan.
Best regards,
Johan.
