drhamad
Sep 04, 2013Aspirant
ReadyNAS X6 not showing up in RAIDar
I've had an X6 for some time (obviously), and it's worked great forever. It's our primary file server. I went to use it today and the shares had disappeared. I pulled up RAIDar and it's not showing...
mdgm-ntgr
Sep 07, 2013NETGEAR Employee Retired
Well try pushing in and holding the power button starting before you connect the power.
I would suggest checking that none of the disks is failing before skipping the volume check.
