mreinfeldt
Nov 07, 2012Aspirant
ReadyNAS X6-TL - changing NIC cards?
Folks, I know I have an ancient device (original Infrant!), but I am interested in upgrading the NIC to at least 100 MB/s (from the 10 MB/s the OOB device came with). I cannot seem to find a compa...
chirpa
Nov 07, 2012Luminary
The ReadyNAS 600B you have does have a Gigabit NIC. Swapping to another gigabit NIC won't give you better speeds. You should max out around 25-30MB/s if your switch/end-device is also gig-capable. You won't see beyond that due to the NSP-chip the system uses, only so much horsepower.
Adding other PCI NICs to the system is not really supported, but a few will work. I believe some RealTek and Intel cards are your best bet.
