mreinfeldt
Nov 07, 2012Aspirant
ReadyNAS X6-TL - changing NIC cards?
Folks, I know I have an ancient device (original Infrant!), but I am interested in upgrading the NIC to at least 100 MB/s (from the 10 MB/s the OOB device came with). I cannot seem to find a compa...
PapaBear1
Nov 08, 2012Apprentice
mreinfeldt - I had that situation with an NV+ (v1) and 100mb/s ports on my router. I was advised by a friend to do exactly what mdgm said, and I went with a gigabit switch and it effectively doubled my throughput to my PC (also with a gigabit NIC). However, I made the mistake of getting a third party switch which proved incompatible when I added a newer ReadyNAS. I would recommend either the Netgear GS105/108 or GS605/608 switches. The 600's are a little fancier, the 100's being in a plain blue metal box. I went with the 8 port, but the 5 port may work ok for you. I put the PCs and the ReadyNAS units on the switch and the printers on the router. (100mb/s is fine for them).
