jjcf89_2
Feb 11, 2022Tutor
ReadyNAS x86_64: Failed to fetch packages for 6.10.3
Can't install packages due to repo 403 errors sudo apt-get upgrade
E: Failed to fetch https://apt.readynas.com/packages/readynasos/dists/6.10.3/main/pool/l/linux/linux-libc-dev_4.4.190.1_am...
jjcf89_2
Feb 11, 2022Tutor
I get the same error when trying to install linux-image-extra
jonathan@dceinas:~$ sudo apt install linux-image-extra [sudo] password for jonathan: Reading package lists... Done Building dependency tree Reading state information... Done The following packages were automatically installed and are no longer required: libio-socket-ip-perl libnih-dbus1 libnih1 Use 'sudo apt autoremove' to remove them. The following NEW packages will be installed: linux-image-extra 0 upgraded, 1 newly installed, 0 to remove and 123 not upgraded. 1 not fully installed or removed. Need to get 6,501 kB of archives. After this operation, 30.7 MB of additional disk space will be used. Err:1 https://apt.readynas.com/packages/readynasos 6.10.3/main amd64 linux-image-extra amd64 4.4.190-610030005 403 Forbidden E: Failed to fetch https://apt.readynas.com/packages/readynasos/dists/6.10.3/main/pool/l/linux/linux-image-extra_4.4.190-610030005_amd64.deb 403 F orbidden E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
