juan_daniel
Mar 09, 2016Aspirant
ReadyNASRND2120 power supply Where to buy?
Model: DSA-60W-12 1 12060 Switching Adapter Where can i buy? Thanks
juan_daniel
I don't know how to find the information to buy a power supply for my product.
In http://support.netgear.com/general/contact/ I can't find the way to get this information.
DaneA
Mar 10, 2016NETGEAR Employee Retired
Hi juan_daniel,
As I have mentioned, you will need to open an online case to inquire your concern. Have you tried to click on "Get help on my NETGEAR product" then proceed with it? Check the image shown below:
DaneA
NETGEAR Community Team
- StephenBMar 10, 2016Guru - Experienced User
It was my understanding that Netgear won't sell you a power brick (though if it failed under warranty they would replace it).
You can try this one (though I haven't purchased it, so I can't recommend it): http://www.amazon.com/Netgear-ReadyNAS-External-replacement-adaptor/dp/B00QC42N6M
