rusaldeev
Jan 27, 2016Aspirant
ReadyNASRND4000 NV+ compatible 220V power unit
Hello, after almost 6.5 years of flawless operation my NV+ just died, looks like power supply was burned, I was actually repositioning my NAS without powering it off, Question is: what is the ex...
- Jan 27, 2016
Hello rusaldeev,
Welcome to the community!
RND4PSU1-10000S is the exact model for the PSU of ReadyNAS NV+v1.
JennC
Jan 27, 2016NETGEAR Employee Retired
Hello rusaldeev,
- rusaldeevJan 27, 2016Aspirant
thanks!
So if I just buy this one, will that fit and work fine?
- StephenBJan 27, 2016Guru - Experienced User
It should, though it is regrettably overpriced. If you have a data backup, you might consider replacing the NAS instead.
You could also look into an overseas supplier - even with shipping costs, it might be quite a bit cheaper.
http://www.evercase.co.uk/CompatibilityListReadynas.htm
http://www.hamiltone.co.uk/menupage.html also claims to have some, though you'd need to email them to get pricing.
thanks, guys!
I just ordered one from the top link you sent (evercase.co.uk), will and replace.
Just last small question: if I just plug 1gb memory in my NAS, one of these below, for example, should it would just fine, no setup or resets needed?
- Oct 03, 2020Retired_Member
