rusaldeev
Jan 27, 2016Aspirant
ReadyNASRND4000 NV+ compatible 220V power unit
Hello, after almost 6.5 years of flawless operation my NV+ just died, looks like power supply was burned, I was actually repositioning my NAS without powering it off, Question is: what is the ex...
- Jan 27, 2016
Hello rusaldeev,
Welcome to the community!
RND4PSU1-10000S is the exact model for the PSU of ReadyNAS NV+v1.
rusaldeev
thanks!
So if I just buy this one, will that fit and work fine?
Jan 27, 2016Guru - Experienced User
It should, though it is regrettably overpriced. If you have a data backup, you might consider replacing the NAS instead.
You could also look into an overseas supplier - even with shipping costs, it might be quite a bit cheaper.
http://www.evercase.co.uk/CompatibilityListReadynas.htm
http://www.hamiltone.co.uk/menupage.html also claims to have some, though you'd need to email them to get pricing.
- rusaldeevJan 27, 2016Aspirant
thanks, guys!
I just ordered one from the top link you sent (evercase.co.uk), will and replace.
Just last small question: if I just plug 1gb memory in my NAS, one of these below, for example, should it would just fine, no setup or resets needed?
- StephenBJan 27, 2016Guru - Experienced User
Additional memory doesn't require any configuration. However, the NAS is quite finicky about memory, and some users have run into problems (specifically with misbehavior when upgrading to current firmware).
Netgear doesn't support memory upgrades (which might matter if you used per-incident support in the future).
So be sure to keep the stock memory around, and run the memory test from the boot menu (for several passes) after installing it.
- JennCJan 27, 2016NETGEAR Employee Retired
Hello rusaldeev,
You might want to see this topic: Memory upgrade of a ReadyNAS NV+
A community member shared his steps.
- Oct 03, 2020Retired_Member
