BobHarris1042's avatar
Apr 24, 2012
Reallocated Sectors increasing on Disk 1
I have a ReadyNAS Duo that is about 2+ years old. Very good device. It is redundant with 2 Seagate Drives, each 1 TB. They are ST31000528AS drives. Firmware is current, 4.1.8. I don't think this unit can be updated to the Firmware 5.x.x series.
Drive #1 (the left hand drive) has been replaced twice. Each time the Reallocated Sector count started to increase. The current drive has started this same behavior. The Reallocated Sector count went from 0 up to 106 over the last 4 weeks. I removed the drive today and connected it to my PC and ran SeaTools to diagnose it. I used the DOS version so that Windows could not be interfering with the utility. I ran only the short test as frankly I didn't have time for the long test (hours). SeaTools found no errors and there are no ATA errors listed by the ReadyNAS. In the past the drives had failed the SeaTools tests. This one may do so in due course (I hope not!)
I'm wondering if the ReadyNAS itself could have a defect that might cause the drives in Disk 1 position to develop the need for Reallocated Sectors and ultimately fail. Has anyone else seen this behavior? If so, what, if anything can be done?
Finally, I'm wondering about the advisability of using SeaTools to erase the drive and let the ReadyNAS rewrite to it. Any thoughts on this would be greatly appreciated also.
I do keep full backups of the NAS as the data is important.
Thank you very much for any thoughts!
--Bob Harris :D
  • Final Resolution:
    I just have to relate this as I think it is a case where everything went well in the end and Netgear really came through.
    I contacted Seagate and they did swap the drive with the increasing reallocated sectors. I also had created a ticket with Netgear. Netgear responded that I should send my ReadyNAS back under RMA and they would swap it. I was really surprised as this was not a new unit by a long shot. I did as instructed and today the replacement ReadyNAS Duo arrived by FedEx. I was not looking forward to setting up the network settings all over again.
    I connected the unit and then went to my router so I could see what IP address had been assigned. When I set these up I always use static IPs. Surprise! There was the NAS using the same IP address as before! I went into it and found that Netgear had transferred all of my settings to the new unit. I am convinced this is not my same old unit; it does not have the same identifying marks.
    I am very impressed with the client service I got from Netgear and also Seagate. To my mind it is unheard of for a company like Netgear to migrate my settings! Great client service!
    Just thought you guys should know.
    --Bob
ProSupport for Business
