mERGER
Oct 10, 2013Aspirant
Realocating sectors same time each day
Is this normal? (see log below) Why does it happen at 04:00 every time? Does something happen then? Is it a "correct" error or just a false positive? Mon Oct 7 04:00:04 CEST 2013 Reallocated sect...
Oct 10, 2013Guru - Experienced User
It is likely real, and you should replace the disk. You can check it on a PC using vendor diags if you wish.
Note that the reallocated sector count is tracked by the drive itself, the NAS is just reporting what the drive is telling it.
