pmzmarketing
Feb 05, 2017Aspirant
Received a ReadyNAS Alert Message Volume:alert email from the RN10200 unit
I recently receive this ReadyNAS Alert Message Volume:alert email that the unit had less than 20% of volume media's capacity is free, however the actual usage is 2.21 TB Free of 2.72 TB or 81% free. ...
pmzmarketing
Feb 07, 2017Aspirant
Thanks Stephan, but no I didn't get it backwards. As you can see on the image below and this is why I have posted the query
Feb 07, 2017Guru - Experienced User
Oops - I misread the original post.
Are you running 6.6.1 with AV enabled? There are some bugs there that are related to this. So you disable AV for now, and see if these alerts stop. There should be a beta posted soon that will have fixes for AV.
- pmzmarketingFeb 07, 2017Aspirant
Thanks Stephan I am using 6.6.1 with AV enabled.Will try disabling the AV and hope that the forthcoming version will fix the issue
