el_patron
Jan 09, 2014Tutor
Recommendation external enclosure with WD 3TB red..?
Hi there, I want to backup my Readynas to an external HD and therefore want to use an WD red 3TB (as it is compatible to the Readynas for maybe later upgrades) within an external USB3.0 enclosure. ...
Jan 10, 2014Guru - Experienced User
I am getting lost in all the "its", so I can't figure out what works.
el.patron wrote: yes i tried it with an sata-usb-interface on my laptop. It worked there. It is an incompatibility of the external enclosure and the WD red 3TB disk.
When you connect the enclosure with the 3 TB WDC disk inside to your PC's USB port, does that work?
