dfulkerson
May 15, 2014Follower
Recommended external USB 4TB for NV+ V2 ?
Hi, Can anyone recommend a 4TB hard drive for NV+ V2 running latest firmware? I made the mistake of ordering this : Seagate Backup Plus 3TB Desktop External Hard Drive USB 3.0 (STCA3000101) ...
Aug 07, 2014Guru - Experienced User
Yes. My NV+ v1 is the backup destination for several shares saved on my Pro-6 (using rsync). I have used frontview backup to copy shares from my RN102 to my Duo v1 as well (again using rsync).
cinskeep wrote: ... Can I easily use the NV+ V.1 as the DESTINATION for a backup (RSYNC or other) if I just put it in an adjacent building and buy another newer ReadyNAS as the data storage unit? ...
File owner/groups might not line up properly, since OS6 uses different UID/GID ranges from the NV+. admin/admin matches, but nothing else does (including nobody/nogroup).
Also, if you go with OS6, if you make the snapshots accessible to the users you need to exclude the snapshot folder from the backup.
