dfulkerson
May 15, 2014Follower
Recommended external USB 4TB for NV+ V2 ?
Hi, Can anyone recommend a 4TB hard drive for NV+ V2 running latest firmware? I made the mistake of ordering this : Seagate Backup Plus 3TB Desktop External Hard Drive USB 3.0 (STCA3000101) ...
Aug 07, 2014Guru - Experienced User
Mine are on different floors, but are all in my home. Perhaps more relevant - they are all on the same LAN segment, but not on the same switch.
It sounds like there's a firewall between the your two locations. Is that correct?
