JS310
Aug 02, 2020Aspirant
Reconfig ReadyNAS 2100 post Factory Default
I am attempting to repurpose my NAS here at home. When I Factory Reset it I am not able to get to the Admin Setup Wizard. I use the new IP address that it obtained and use the default username and ...
Marc_V
Aug 03, 2020NETGEAR Employee Retired
Using RAIDar you should be able to run the setup. Have you tried accessing it via NAS_IP/admin? or have you finished the setup already?
HTH
Aug 03, 2020Guru - Experienced User
You do need explicitly browse to https://nas-ip-address/admin
It won't redirect to the admin page if you just browse to https://nas-ip-address
The username must be admin; the password for OS 4.2.x is netgear1.
- JS310Aug 03, 2020Aspirant
Yup. I did try that as suggested and it does not work either. Is there a way to reinstall the OS...besides the boot OS Reinstall? That did not seem to work either. Now I cannot ping the device or access the Shares page.
- StephenBAug 03, 2020Guru - Experienced User
Do you have an ad blocker or internet security software (avast, kaspersky, etc) running? Try disabling if if you do.
Also, are you getting a security warning? You do need to click through that.
I decided to reboot it and try the OS install again but after the reboot it came back to life and is online. Please see the attachment. Should/can I upgrade to 6? If so what is the preferred upgrade path? Thanks again for your help.
