JohnPud's avatar
JohnPud
reconfigure readynas 104
Posted elsewhere but hadn't considered business solutions - sorry. My readynas 104 was configured with disk 1 and 2 as raid 0 and disks 3 and 4 as two jbod volumes. I decided to split disks 1 and 2 as two jbod. I removed all disks, cleaned disks 1 and 2, did a factory reset and set them up as 2 jbod volumes. Can I now safely return disks 3 and 4 without losing the data?
  • StephenB's avatar
    Did you export the two jbod volumes before you removed the disks?
    If not, then try powering down the NAS, removing disks 1 and 2, and booting up the NAS with only disks 3 and 4 installed.  The RAID-0 volume will show up as failed/not present.  Then see if you can export the two jbod volumes.
    If that works (or if you previously exported the volumes), then power down, insert all disks, and power up again.
    • JohnPud's avatar
      JohnPud
      Thanks for the quick reply. The current situation is disks 1 and 2 are installed as 2 x jbod and I am restoring files to them as I write. So can I now return disks 3 and 4 without losing the data on them? I'm just worried that the factory reset may have done something that causes the nas to format  them instead of simply mount them.
      • StephenB's avatar
        No, that is not what I said.  Go back and read post # 2 again.  Pay particular attention to the need to export the volumes.
        You can of course back up the files on disks 3 and 4 when you boot up the system with only those disks in place.
ProSupport for Business
