RJSConsultants's avatar
Apr 28, 2020
Recover password not working
Hi
Trying to recover my lost password however an error comes up when going through the forgot password on the readycloud site:
'There was an error recovering the password.
Please retry.
null'
I cannot get a recovery email
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    RJSConsultants
    Welcome to the Community!
    Have you set Password recovery thru Email before? Have you tried using a different browser?
    If Email recovery was setup before then it should get you a recovery E-mail once successfully done. Maybe trying other browser first or even another PC might help.
    Otherwise, if you have not set it up or still having the same issue after trying on another, doing OS-Reinstall would be the next solution.
    HTH
    • RJSConsultants's avatar
      RJSConsultants
      HI
      I have tried on multiple pc's as well as different accounts that I have used the forgot password option on, as well as my phone.  The message still comes up.  I think it may be a problem with the website itself (http://readycloud.netgear.com/)
      I put a screenshot of the error in my first post.
      • Sandshark's avatar
        Sandshark
        Sensei
        Do you have email alerts enabled, and do they work?
        If all else fails, you still have the option of an OS re-install, which sets the password to the default but does not mess with your data.  It does also switch IP addressing to DHCP, should you currently have it as static.
ProSupport for Business
