wastedyouth1
Nov 18, 2012Aspirant
Repeating GPF
Hi I was wondering if anyone could advise on the cause of the GPF's I'm seeing in the syslog of my ReadyNas Pro. These happen once a week at least an normally result in my having to powercycle the...
Andlier
Dec 10, 2012Tutor
I have the same issues with my readynas ultra 6 device:
I have already been in contact with support about this, they adviced me to do a factory reset, which I did. But the problem reappeared after about two months. I also have a readynas pro 2 which had the same problem, but that box has been fine after I did a factory reset a couple of months ago. The problems seemed to start for me when I updated to 4.2.22. I'm running the memory test now, plan to run it at least one week, no errors yet after 20 hours.
Dec 9 23:31:06 AndersNAS kernel: general protection fault: 0000 [#1] SMP
Dec 9 23:31:06 AndersNAS kernel: last sysfs file: /sys/devices/virtual/block/md2/md/sync_action
Dec 9 23:31:06 AndersNAS kernel: CPU 1
Dec 9 23:31:06 AndersNAS kernel: Modules linked in: pvgpio nv6lcd nv6vpd(P)
Dec 9 23:31:06 AndersNAS kernel: Pid: 14828, comm: sleep Tainted: P 2.6.37.6.RNx86_64.2.4 #1 /
Dec 9 23:31:06 AndersNAS kernel: RIP: 0010:[<ffffffff880ac8c7>] [<ffffffff880ac8c7>] filp_close+0x17/0x90
Dec 9 23:31:06 AndersNAS kernel: RSP: 0000:ffff880038e8bf28 EFLAGS: 00010286
Dec 9 23:31:06 AndersNAS kernel: RAX: fffffffffffffffd RBX: fc985e97ea331f00 RCX: 0000000000000001
Dec 9 23:31:06 AndersNAS kernel: RDX: 0000000000000000 RSI: ffff880039114580 RDI: fc985e97ea331f00
Dec 9 23:31:06 AndersNAS kernel: RBP: ffff880038e8bf48 R08: 0000000000000001 R09: 00000000ffb35190
Dec 9 23:31:06 AndersNAS kernel: R10: ffff880038e8a000 R11: 0000000000000000 R12: ffff880039114600
Dec 9 23:31:06 AndersNAS kernel: R13: 0000000000000001 R14: fc985e97ea331f00 R15: 0000000000000000
Dec 9 23:31:06 AndersNAS kernel: FS: 0000000000000000(0000) GS:ffff88003f280000(0063) knlGS:00000000f75b78c0
Dec 9 23:31:06 AndersNAS kernel: CS: 0010 DS: 002b ES: 002b CR0: 000000008005003b
Dec 9 23:31:06 AndersNAS kernel: CR2: 00000000f761e5d0 CR3: 000000003d87e000 CR4: 00000000000006e0
Dec 9 23:31:06 AndersNAS kernel: DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
Dec 9 23:31:06 AndersNAS kernel: DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
Dec 9 23:31:06 AndersNAS kernel: Process sleep (pid: 14828, threadinfo ffff880038e8a000, task ffff88003d9638e0)
Dec 9 23:31:06 AndersNAS kernel: Stack:
Dec 9 23:31:06 AndersNAS kernel: 0000000000000000 ffff880039114580 ffff880039114600 0000000000000001
Dec 9 23:31:06 AndersNAS kernel: ffff880038e8bf78 ffffffff880adae4 0000000000000001 0000000000000000
Dec 9 23:31:06 AndersNAS kernel: 0000000000000000 0000000000000000 00000000ffb35190 ffffffff88024c53
Dec 9 23:31:06 AndersNAS kernel: Call Trace:
Dec 9 23:31:06 AndersNAS kernel: [<ffffffff880adae4>] sys_close+0xa4/0x100
Dec 9 23:31:06 AndersNAS kernel: [<ffffffff88024c53>] ia32_sysret+0x0/0x5
Dec 9 23:31:06 AndersNAS kernel: Code: 83 80 00 00 00 48 8b 1c 24 4c 8b 64 24 08 c9 c3 66 66 66 90 55 48 89 e5 48 83 ec 20 48 89 5d e8 4c 89 65 f0 48 89 fb 4c 89 6d f8 <48> 8b 47 30 49 89 f4 48 85 c0 74 52 48 8b 47 20 48 85 c0 74 44
Dec 9 23:31:06 AndersNAS kernel: RIP [<ffffffff880ac8c7>] filp_close+0x17/0x90
Dec 9 23:31:06 AndersNAS kernel: RSP <ffff880038e8bf28>
Dec 9 23:31:06 AndersNAS kernel: ---[ end trace 739a60f4dab3e474 ]---
Dec 9 23:31:08 AndersNAS kernel: general protection fault: 0000 [#2] SMP
Dec 9 23:31:08 AndersNAS kernel: last sysfs file: /sys/devices/virtual/block/md2/md/sync_action
Dec 9 23:31:08 AndersNAS kernel: CPU 3
Dec 9 23:31:08 AndersNAS kernel: Modules linked in: pvgpio nv6lcd nv6vpd(P)
Dec 9 23:31:08 AndersNAS kernel: Pid: 14828, comm: sleep Tainted: P D 2.6.37.6.RNx86_64.2.4 #1 /
Dec 9 23:31:08 AndersNAS kernel: RIP: 0010:[<ffffffff880ac8c7>] [<ffffffff880ac8c7>] filp_close+0x17/0x90
Dec 9 23:31:09 AndersNAS kernel: RSP: 0000:ffff880038e8bcd8 EFLAGS: 00010286
Dec 9 23:31:09 AndersNAS kernel: RAX: ffff880001509818 RBX: fc98020004060008 RCX: 0000000000000000
Dec 9 23:31:09 AndersNAS kernel: RDX: 0000000000000000 RSI: ffff880039114580 RDI: fc98020004060008
Dec 9 23:31:09 AndersNAS kernel: RBP: ffff880038e8bcf8 R08: ffff880038e8a000 R09: 0000000000000001
Dec 9 23:31:09 AndersNAS kernel: R10: 0000000000000000 R11: 0000000000000000 R12: ffff880039114580
Dec 9 23:31:09 AndersNAS kernel: R13: 0000000000000000 R14: ffff8800316ac600 R15: 0000000000000018
Dec 9 23:31:09 AndersNAS kernel: FS: 0000000000000000(0000) GS:ffff88003f380000(0000) knlGS:0000000000000000
Dec 9 23:31:09 AndersNAS kernel: CS: 0010 DS: 002b ES: 002b CR0: 000000008005003b
Dec 9 23:31:09 AndersNAS kernel: CR2: 00000000567b602c CR3: 000000003167b000 CR4: 00000000000006e0
Dec 9 23:31:09 AndersNAS kernel: DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
Dec 9 23:31:09 AndersNAS kernel: DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
Dec 9 23:31:09 AndersNAS kernel: Process sleep (pid: 14828, threadinfo ffff880038e8a000, task ffff88003d9638e0)
Dec 9 23:31:09 AndersNAS kernel: Stack:
Dec 9 23:31:09 AndersNAS kernel: ffff88003d3ac380 0000000000000039 ffff880039114580 0000000000000000
Dec 9 23:31:09 AndersNAS kernel: ffff880038e8bd38 ffffffff88036843 0000000000000000 ffff88003d9638e0
Dec 9 23:31:09 AndersNAS kernel: ffff880039114580 ffff88003d9638e0 0000000000000071 ffff88003930a1c0
Dec 9 23:31:09 AndersNAS kernel: Call Trace:
Dec 9 23:31:09 AndersNAS kernel: [<ffffffff88036843>] put_files_struct+0xc3/0xd0
Dec 9 23:31:09 AndersNAS kernel: [<ffffffff88036895>] exit_files+0x45/0x50
Dec 9 23:31:09 AndersNAS kernel: [<ffffffff88037a20>] do_exit+0x190/0x770
Dec 9 23:31:09 AndersNAS kernel: [<ffffffff88002bce>] ? apic_timer_interrupt+0xe/0x20
Dec 9 23:31:09 AndersNAS kernel: [<ffffffff88035fd0>] ? kmsg_dump+0x110/0x160
Dec 9 23:31:09 AndersNAS kernel: [<ffffffff88006506>] oops_end+0xa6/0xb0
Dec 9 23:31:09 AndersNAS kernel: [<ffffffff88006606>] die+0x56/0x90
Dec 9 23:31:09 AndersNAS kernel: [<ffffffff880040f2>] do_general_protection+0x152/0x160
Dec 9 23:31:09 AndersNAS kernel: [<ffffffff885b48ef>] general_protection+0x1f/0x30
Dec 9 23:31:09 AndersNAS kernel: [<ffffffff880ac8c7>] ? filp_close+0x17/0x90
Dec 9 23:31:09 AndersNAS kernel: [<ffffffff880adae4>] sys_close+0xa4/0x100
Dec 9 23:31:09 AndersNAS kernel: [<ffffffff88024c53>] ia32_sysret+0x0/0x5
Dec 9 23:31:09 AndersNAS kernel: Code: 83 80 00 00 00 48 8b 1c 24 4c 8b 64 24 08 c9 c3 66 66 66 90 55 48 89 e5 48 83 ec 20 48 89 5d e8 4c 89 65 f0 48 89 fb 4c 89 6d f8 <48> 8b 47 30 49 89 f4 48 85 c0 74 52 48 8b 47 20 48 85 c0 74 44
Dec 9 23:31:09 AndersNAS kernel: RIP [<ffffffff880ac8c7>] filp_close+0x17/0x90
Dec 9 23:31:09 AndersNAS kernel: RSP <ffff880038e8bcd8>
Dec 9 23:31:09 AndersNAS kernel: ---[ end trace 739a60f4dab3e475 ]---
Dec 9 23:31:09 AndersNAS kernel: Fixing recursive fault but reboot is needed!
