wastedyouth1
Nov 18, 2012Aspirant
Repeating GPF
Hi I was wondering if anyone could advise on the cause of the GPF's I'm seeing in the syslog of my ReadyNas Pro. These happen once a week at least an normally result in my having to powercycle the...
pjos
Feb 05, 2013Aspirant
Andlier wrote: I've not solved the issue by contacting tech-support.
Hmm, not good :-( ,
I have two Ultra 4 boxes, one of them with two for the moment supported disks ST2000DM001, the GPF problem started suddenly after one months of flawless operation. The other Ultra4 with four disks (those have been removed from HCL), has benn running for 6 moths without any problems.
Is there way to check BIOS version?
