fkearney
Apr 12, 2014Aspirant
Replacement for NV
I had my NV stored for a year, and when I hooked it up today, there was no response. I put a tester on the power supply and it appears to have failed while in storage. Rather than replace the power...
Apr 12, 2014Guru - Experienced User
If you mean "preserving the data", then no. None of the currently shipping NAS are compatible.
fkearney wrote: I had my NV stored for a year, and when I hooked it up today, there was no response. I put a tester on the power supply and it appears to have failed while in storage.
Rather than replace the power supply I would like to just get a new ReadyNAS. The NV is equipped with four WD5002ABYS drives. Is there a newer ReadyNAS I can migrate these drives to, and have it work correctly?
Thanks
Frank
You can mount them in a x86 linux system. If you have an ATX power supply handy (and are willing to make a custom cable) you can rig something that will work at least long enough to get the data off.
