fkearney
Apr 12, 2014Aspirant
Replacement for NV
I had my NV stored for a year, and when I hooked it up today, there was no response. I put a tester on the power supply and it appears to have failed while in storage. Rather than replace the power...
fkearney
"You can mount them in a x86 linux system"... Does this mean if I boot my XP machine into Linux I will be able to read the data if I connect the drive through USB?
Thank you for your help.
Frank
Frank
