fkearney
Apr 12, 2014Aspirant
Replacement for NV
I had my NV stored for a year, and when I hooked it up today, there was no response. I put a tester on the power supply and it appears to have failed while in storage. Rather than replace the power...
Apr 13, 2014Guru - Experienced User
Yes, though you need to connect up the entire array. There's a guide here: http://home.bott.ca/webserver/?p=306
