fkearney
Apr 12, 2014Aspirant
Replacement for NV
I had my NV stored for a year, and when I hooked it up today, there was no response. I put a tester on the power supply and it appears to have failed while in storage. Rather than replace the power...
fkearney
Apr 13, 2014Aspirant
Well, I think on my best day I could never figure that out - much too arcane for my pea brain. Aside from all the words I don't understand, figuring out how to connect them all together, get power to them all and then which one would be the one to connect to USB......
Do you have a link to how I might configure an ATX power supply custom cable, Stephen? Maybe I could just cut the ends off the existing cable on the failed power supply and splice/insert into the ATX long enough to remove the data.
Thanks again for your time.
Frank
Frank
