fkearney
Apr 12, 2014Aspirant
Replacement for NV
I had my NV stored for a year, and when I hooked it up today, there was no response. I put a tester on the power supply and it appears to have failed while in storage. Rather than replace the power...
Apr 13, 2014Guru - Experienced User
The pinout used is here: http://www.readynas.com/download/archiv ... pinout.pdf
You could get an ATX cable extender, and modify that.
