fkearney
Apr 12, 2014Aspirant
Replacement for NV
I had my NV stored for a year, and when I hooked it up today, there was no response. I put a tester on the power supply and it appears to have failed while in storage. Rather than replace the power...
fkearney
Apr 19, 2014Aspirant
Another question please - I have 2 x NV+ machines as well - could I use the power supply from one of those to fire up the NV and remove the data - doesn't seem like a big deal to remove the PS and put it back. I only need it working for an hour.
Thank You
Frank
Thank You
Frank
