fkearney
Apr 12, 2014Aspirant
Replacement for NV
I had my NV stored for a year, and when I hooked it up today, there was no response. I put a tester on the power supply and it appears to have failed while in storage. Rather than replace the power...
Apr 19, 2014Guru - Experienced User
If the firmware on the 2 other machines matches the failed one, then you have an even simpler option.
Just power down one of the working machines. Remove the drives, label them by slot. Then put the drives from the failed machine into the working one (preserving slot order) and power it up!.
If the firmware doesn't match, then the NAS will attempt to upgrade/downgrade the OS partition to match what's in its flash. Usually that is not a problem, but if the firmware is seriously mismatched it is a bad idea.
