fmarchitects
Jan 09, 2012Aspirant
Replacement NV+ chassis
My NV+ went up in smoke yesterday and I'm expecting a replacement chassis from the nice people at Netgear. The RMA is showing the model as RND4000-300WWB. Is this a Readyas NV+ v1 or V2? and which Rai...
mdgm-ntgr
Jan 09, 2012NETGEAR Employee Retired
Well considering you currently have a NV+ v1, the replacement chassis would also be a NV+ v1.
The NV+ v2 is going by the model number RND4000-200
It can be a bit confusing.
If you have a spare disk (not from your array) you could put that in the NAS and confirm it's running RAIDiator 4.1.x or earlier. I'd suggest updating the NAS to the latest firmware, verify update completed successfully, then power down, remove the spare disk and migrate your disks across: http://www.readynas.com/kb/faq/boot/how_do_i_migrate_disks_over_from_an_existing_readynas_to_another
