fmarchitects
Jan 09, 2012Aspirant
Replacement NV+ chassis
My NV+ went up in smoke yesterday and I'm expecting a replacement chassis from the nice people at Netgear. The RMA is showing the model as RND4000-300WWB. Is this a Readyas NV+ v1 or V2? and which Rai...
fmarchitects
Jan 11, 2012Aspirant
Thanks mdgm,
I'm pretty sure I followed your migration info - I used a spare disk to upgrade the firmware, then migrated the disks, then recalibrated the fan. Frontview reported a resync of the disks and everything seems ok. I'm not sure how you check the firmware match between flash and disk?
I've migrated to User mode as per the link - does that mean setting up individual users/password logons for each machine?
Thanks
Thanks
