Bobski2000
Sep 04, 2018Tutor
Replacement part wanted
Hi,
can anybody help please.
i need a replacement front, where the buttons go etc... I’ve tried looking at Netgear site with no luck.
- Sep 04, 2018
Hi Bobski2000
Welcome to the Community!
Unfortunately there is no replacement part for the front panel. The best thing we can suggest is to get another Pro4 from a user or online store.
More or less your Pro 4 is already Out of waranty so getting a newer model is better. ReadyNAS OS 6 models.
IMO, getting a newer model NAS would be the best way to move forward here since Pro 4 is already EOL. Migrating data to OS 6 is easy as there is a guide for that.
What happened to this NAS btw?
Hope this helps!
Regards
Sep 04, 2018Guru - Experienced User
Unfortunately Netgear doesn't sell replacement parts.
Options are
- to find a used unit (either using it for parts, or migrating your disks to it). Anything you find will be at least 5 years old.
- replace the NAS with a current OS 6 x86 model. You can temporarily mount your disks in the new ReadyNAS, allowing you to offload the data to a backup. Then you'd complete the setup and restore the data from the backup.
Bobski2000
Sep 04, 2018Tutor
Thank you
