Floob1
Jul 31, 2012Aspirant
Replacement Power Supply for ReadyNAS NVX? Case #19099497
Hi, It seems as though the power supply on our NVX ReadyNAS (RNDX4210) has failed. Where can I buy a replacement from that will be ok in the unit? Regards, Floob.
mdgm-ntgr
Aug 02, 2012NETGEAR Employee Retired
A newer firmware should be fine. You just don't want the Pro 4 to have any old firmware than 4.2.16 on it before doing the migration. After the migration you'll want to install the latest firmware as per the FAQ: http://www.readynas.com/kb/faq/boot/how_do_i_migrate_disks_over_from_an_existing_readynas_to_another
