Floob1
Jul 31, 2012Aspirant
Replacement Power Supply for ReadyNAS NVX? Case #19099497
Hi, It seems as though the power supply on our NVX ReadyNAS (RNDX4210) has failed. Where can I buy a replacement from that will be ok in the unit? Regards, Floob.
Floob1
Aug 02, 2012Aspirant
It all went smoothly, the Pro came with 4.2.17 installed and I believe it wrote some update to the disks (although the disks were on a newer firmware) and it all went smoothly and retained our security settings etc..
We have now updated the firmware to 4.2.21
Thanks for your help.
