iposner
Apr 13, 2013Aspirant
Replacement Power Supply for UK NV+
I have an NV+. After shutting it down cleanly the other day, it now won't switch on. There's no light when I press the power button, no noise/fans/etc. I've tried changing the power lead, but it's dea...
Apr 13, 2013Guru - Experienced User
There might be some still out there, though they seem to be very hard to find.
It is possible to modify the cable in a standard ATX supply, however the supply is unlikely to fit inside the chassis. http://www.readynas.com/download/archiv ... pinout.pdf
