stephen7005
Sep 20, 2012Aspirant
Replacing a hard drive
I have a Readynas Duo with two identical Seagate Barracuda 1TB drives (ST31000528AS). One of the drives just died and I need to replace it. Can I replace it with a different type of drive? From rea...
PapaBear1
Sep 20, 2012Apprentice
As long as the replacement drive is on the Hardware Compatibility List (HCL) and is equal to or larger than the smallest drive in the array. You can mix brands, models and even 5400/5900/7200 RPM drives.
Note: Western Digital does not recommend their Green Label drives in RAID configurations, but are on the HCL. A better choice, although a bit more expensive is their Red Label series which are expressly designed for RAID use. Enterprise drives of all manufacturers which are far more expensive are also designed for RAID use.
I have run arrays with 2x1TB Seagate 7200RPM drives and 2x3TB Hitachi 5400RPM drives without any problems for the past year. Prior to that for about a year, I ran an NV+ with 4 drives of 2 different manufacturers, 2 different models and 2 different sizes. Of the four drives only two were the same make and model.
