markg1
Sep 08, 2011Aspirant
Replacing Nv+ with pro 6?
i first bought an NV+ with 4x 750gb and it worked great, and backed it up to one of the desktop computer boxes. As time went on i ran out of room, and upgraded to a PRO Business with 6x 1tb in raid 6...
markg1
Sep 12, 2011Aspirant
PapaBear wrote: I was only using it for comparative purposes. The Deskstar is a very good compromise because of the rotational vibration. I have had all Seagates in my units, but my last drives were the HDS5C3030ALA630 3TB "Green" drives. They are performing very well for me, but have been in service for less than 3 months, so we shall see. The Hitachi drives seem to have a very good service record.
i understand.
im concerned about the lack of vibrational resistance in the standard seagate drives since 6 of these things are right next to each other, and i dont need the downtime.
still trying to figure if the price difference is warranted between the deskstar and constellation. the hitachi ultrastar is much more expensive than the constellation, but if you can believe the stats, has a 2Million hour mtbf, vs 1.2 for the constellation and 1 for the others. but that stat means nothing if its MY drive that dies....
