markg1's avatar
markg1
Replacing Nv+ with pro 6?
i first bought an NV+ with 4x 750gb and it worked great, and backed it up to one of the desktop computer boxes.
As time went on i ran out of room, and upgraded to a PRO Business with 6x 1tb in raid 6, backing that up to the NV+
now its time to upgrade again, to a PRO 6 i think. Plan to back this up to the Pro business, and get rid of the NV+ unless i can think of some use for it (but i cant; its too slow to do much with other than data storage, and it only has 4x750gb storage)
i need to run raid 6 (in xraid II i suppose, didnt have that option when i got the Business PRO), but im not sure how to configure it.
if i get 3tb drives, i need 4 to run raid 6 i think. that would leave me a nice buffer of an additional 6gb by adding 2 more drives when needed. and i see some 3tb drives on the compatibility list, although they are pricy ($315 on amazon). my prior boxes all used enterprise drives; is that important now, or are the normal drives good enough these days? or do i just need to make sure they have the vibration feature?
also, any recommendations as to where to buy? the last two were from aegis, but them seem to have dropped most of the readynas line. i liked them because they burned in what you bought, and that caught bad parts. anyone else with a reasonable price do this?
thanks for any help
mark
  • Unfortunately the retailers don't give a reason when they drop a product. Many times it has been discontinued, but sometimes it's also because of lack of demand.
  • ended up ordering the enterprise drives after i thought about the price difference and the problems i have if it goes down.
    just losing that disk the other week wasted time i would rather get back....
    setting it up now, debugging the last of the issues (always backup, go figure) and when completed + 1 week to make sure everything is stable, i will install the replicate trial to see if that is worthwhile or not. but in the meantime, it works!
    thanks everyone for the thoughts, it helped to make the decision
    mark
ProSupport for Business
