srvteam
Jul 06, 2017Aspirant
Replication License for ReadyNAS 2100v2
I have two of these that I'd like to use with replication but can't find any way to get the license for either. The device specifics are as follows: ReadyNAS 2100 v2 Serial: 2KU427R800545 Firmw...
Jul 06, 2017Guru - Experienced User
If you google on RN00RPL1 you'll find a couple of sources.
They are pretty expensive - another alternative is to switch the 2100s to OS 6 (which is free). That will work on the v2, but not the v1. Netgear doesn't support this, but of course the hardware warranty still applies.
