Totor8602
Jun 01, 2024Follower
Request help Malfunction Netgear ReadyNAS 214
Hi. I have a Netgear ReadyNAS 214, bought in 2017. This one doesn't work anymore. When I start it, it boots up to 98% and then nothing happens. Can I buy a new Netgear ReadyNAS and use the disks with...
Jun 01, 2024Guru - Experienced User
You might get better help posting in the readynas forums versus the netgear Armor forums.
