rfdnga
Jul 11, 2025Aspirant
Reset 524x and need advice
I am giving my 524x to a friend that has Iphones and notebook pc. After defaulting the device (software version 6.10.10 I realized that the apps were gone and reading here I found where installin...
Jul 19, 2025Guru - Experienced User
rfdnga wrote:he would like his notebook to back up to his home system from home or office
The best way to accomplish that is to set up a VPN at home. Some routers have built-in VPN servers (for example, Netgear's Orbi and Nighthawk routers have OpenVPN - which I use myself). Zerotier is another possibility that could be installed on the notebook, the phones, and the NAS.
He can then install backup software on the notebook that has the NAS as a destination. FreeFileSync is one of many options.
rfdnga wrote:After defaulting the device (software version 6.10.10 I realized that the apps were gone and reading here I found where installing 6.10.7 the apps were then showing up .
There are changes to apt that you'd need to make. That is because Debian Jessie (the NAS OS) has been deprecated, and the Debian community has moved the library repos to archives.
Instructions are here:
rfdnga wrote:what is the best app to install to hopefully automatically backup their iphones
Not sure what is "best". Resilio Sync is one option. iTunes running on a Windows PC is another (though not easily automated).
Though using iCloud is worth considering (either instead of, or in addition to).
