jevakmeni
Jul 20, 2023Follower
Resetting Netgear Readynas RNDP2230 to factory defaults
Hey All I'm having trouble to reset a Netgear Readynas RNDP2230. I have followed the procedure as indicated in the manual but after resetting the device the previous config returns. Any help would...
Sandshark
Jul 20, 2023Sensei
Are you doing it with the drives installed? They are what gets reset. None of your configuration is stored in flash memory. An alternative is to simply zero the drives with a PC.
