berillio
May 21, 2014Aspirant
resinch a dieing disk or add new disk & resinch?
Apologies again. I posted the same message in the "Test" board, and got complete unnoticed / unseen. As it is rather urgent, I am re-posting it here, where I hope it will be seen. I could not find a b...
berillio
running diags on another pc
HIREN CD14
HDD Scan for Windows vers 3.3
ST3000DM001-9YN166-W1F0WXJW
Firmware CC4B
LBA 156 556 5872
SMART Class not registered (... ??? )
then PC died. :-(
rebooted and loaded Seagate disk Wizard
Nope, it is a Clone /Image / Add disk proggie, no diagnostic
on a 3rd reboot I manage to stop the POST info, SMART Capable and Staus OK
running Seagate Seatools
"Smart is supported and Enabled"
"SMART has NOT been Tripped"
DST is Supported
Logging feature set IS supported
POH 12917, Current temp 32"
Started Short Test @23:27.39
Short DST Passed @23:28.43
Started Long Test @23:29.40 currently running, it may take a while, after 5 mins I only a single line in the Progress bar - it may take 2h or more)(if the pc does not die again)
HIREN CD14
Firmware CC4B
LBA 156 556 5872
then PC died. :-(
DST is Supported
