berillio
May 21, 2014Aspirant
resinch a dieing disk or add new disk & resinch?
Apologies again. I posted the same message in the "Test" board, and got complete unnoticed / unseen. As it is rather urgent, I am re-posting it here, where I hope it will be seen. I could not find a b...
berillio
Jun 20, 2014Aspirant
OK, run SeaTools on an oldish PC with a floppy drive (could not save the SeaTools logs, which could not be written to CD).
All SeaTools tests were passed (again), including the ERASE test. No particular infos about finding and relocating/moving bad/slow sectors but I do not know if this would have been reported.
My general feeling is that the disk was fine all along, and ReadyNAS threw a wobble /false alarm. I just checked the firmware, it is on RAIDiator 5.3.9, and I have downloaded 5.3.10 which I will install shortly, but there seem to be no relevant changes / bug fixes, only enhancements to cater for newer systems.
We played safe, but "better safe than sorry" - old adagios have a reason to exist !
Thanks !
Here is the SeaTools Logs, I was experimenting as I did not know if it wrote a new log or it added to it everytime.
--------------- SeaTools for DOS v2.23 ---------------
Device 0 is Seagate Device ST3000DM001-9YN166 W1F0WXJW On Intel ICH5
Max Native Address 5860533167
Device is 48 Bit Addressed - Number of LBAs 5860533167 ( 3000.593 GB )
This drive supports Security Features
SMART Is Supported And ENABLED
SMART Has NOT Been Tripped
DST Is Supported
Logging Feature Set Is Supported
POH 13517 Current Temp 35
Started Short DST 6/18/2014 @ 19:36.28
DST Completed Without Error
Short DST PASSED 6/18/2014 @ 19:37.33
DST Is Supported
Started Short DST 6/18/2014 @ 19:47.34
Short DST PASSED 6/18/2014 @ 19:48.38
DST Is Supported
Started Long Test 6/18/2014 @ 19:49.21
Short DST PASSED 6/19/2014 @ 0:17.21
Long Test PASSED 6/19/2014 @ 0:17.21
DST Is Supported
POH 13522 Current Temp 36
Started Full Erase 6/19/2014 @ 1:10.37
Full Erase PASSED 6/19/2014 @ 21:41.58
Thanks !
DST Is Supported
DST Is Supported
DST Is Supported
DST Is Supported
