is0lde
Jul 10, 2011Aspirant
Resync Issues with Barracuda LP ST2000DL003
3 days ago I Expanded to 2 TB using the above disks. I have done 2 volume resync's now. yesterday I was getting error messages when streaming - File no longer available and or connection failed. I al...
gerardhoran
Aug 11, 2011Aspirant
I just added a second ST2000DL003 to my Nas Duo.
( removed a 1.5 TB Seagte and added this 2 TB drive to add raid to my existing 2 TB ST32000542AS and to increase the total capacity which was limited by the 1.5 TB Drive)
The first ST200DL003 did not work at all so I sent it back to Amazon, the second drive they sent me seemed to work flawlessly. It detect the drive, re synced and then flawlessly did the Volume Expansion. ( required 2 reboots)
The first day I got a SATA reset on the new drive and had to resync. That seemed to go ok, then I noticed my Time Machine Backups were failing. Again when more SATA resets and the performance was AWFUL.
At this point I have removed the ST200DL003 and am running with no X Raid on a single 2 TB ST32000542AS
All is working fine.
I am suspicious of the ST200DL003 Drives in the DUO, can anybody confirm that these drives work reliably in the NET NAS Duo?
ger
ger
